hi all, check out my 2nd run for the 5sc ss
[ame]http://youtu.be/NZ8Zl8_gdoc[/ame] and http://youtu.be/zdUpQSiiqnM:lol:
Listen to it when he backs off the throttle. I was always told this is a lean condition. Guess time will tell.
you should be running it rich for its first two tanks with 20min run times letting it fully cool in between runs after that its fully broken in then tune it to its maximum performance.....make sure you use a high quality 2 stroke oil
Troy
Thanks Troy.. did that, done. next week i will tweek the carb. hope i know what im doing. lol
but it runs hard and wow it just wants to go...
Yeah their very addictive, here's alink to help you with tuning your engine
https://www.largescaleforums.com/showthread.php?t=12881
Troy
Did you check the carb settings to make sure they are at factory settings according to the manual?
yes i did.. the same..
