my Fg baja competition 4wd
updating post....
just comes some objects...the blue silicon exhaust hose, mammooth glued tires, smartech wing...
mammooth tires,mounted on original fg wheels NOT fit with stock square wheels adapter.. u need 2 pairs of 6107 wheel square 9,5mm/M6..
also the wing's hole doesn't fit.. i just re-drill it..
this is the result... i like it very much..
:clown::clown:
i think u should me send.. :blush::blush::):)
certainly i'll stick them...
however.. today make some minor mods, put some other stickers, and run 200cc to tune the carb...
wonderful car..
on 20th maybe i'll going on a specific 1/5 off road circuit...
hope to keep some good pics..
so... some other mods on my comp..
i installed a Lautherbacher gas cap... simply wonderfull and very quick..
also i use two A123 cell for the on board electronic.. 2300mah for 6+ volts .. i prefer this solution on this car because if by one 2300 are not too much, i know in every moment that i can go in garage and switch on my baja, cause like lipo's, they haven't auto discharge....
came back to the cap, with this i lose the pressure valve... so using a motocross one, i drill the tank, using 2 o-ring i install a new pressure valve on it...
simply a great job in my opinion...
thank u
bye
awesome stuff mate, thats one awesome machine, really enjoying reading this thread.
are the diff housings and front upper swing arms alloy standard or did you upgrade to them?
very interesting.. finally new alloy front shock tower and Alloy roll cage bracket from rc-car online...
next order will be mine...
http://www.rc-car-online-shop.de/ls...--tuning.vorderachse.fg_4wd_front--y0579,.htm
http://www.rc-car-online-shop.de/lshop,showdetail,,e,,,y0579,,,.htm
awesome stuff, been waiting for these, im going to contact the FG importer here in oz and see if he can get his hands on some. I really dislike the plastic suspension mount, so much flex!
