Retired_Raver
- Thread starter
- #21
nice one raver but does the carbon filter still fit as the shells a fair bit lower than the bmw shell
you are right ...i need to cut the engine window so that it gets through a little
the tyres where meant for eating....i did some modifications and set up andthink it needs a bit more power raver lol
i bet its eating up the rear tyres now mate,,still looks a handfull but great fun
thank you jf813wor Raver, you got some power in that thing. Nice car man. :cup-1:
it can go straight....but still has many throttle to go on...most of the time i used half and maybe 70% of it . when i find time i will search for better set up
no problem mate comments and other opinios are welcome . The engine is a full trevor simpson reed 28.5 with some modifications by me....it was not meant for an on road car as it revs from low ....the combination with the mod wt 257 and the malossi macsi make it run crazy from very low rpm...the throttle as you see reacts crazy . If i could fit the victory pipe as i have in my mt it would fly . I am not a racer (i am a modelist guy ) but i like to build my cars in the best way i can...for the set up i am in the search i do not have your experience as i like mt's most .im using this info as a base setup for mine its for a fg evo but cant see why it wont work on your car
http://www.fg-info.co.uk/viewtopic.php?f=30&t=10
ps im not knocking your car in anyway mate i get it,,,loads of powers better than not enough any day trust me mines got more than enough power and its great fun and is a handfull as well but thats what i want
and if that was yours on just 70% throttle then that thinks going to be mega fast once you get the setup right have you thought about upping the gearing a little
the 771 is a good carb but for the ts motor the mod 257 works better , i know because i tried both and the 813 and the 668 .603 and the 404 . The only carb i would change it for is the enforcer big bore or a barrel type carb .The enforcer is very rare to find and a barrel type needs a lot of work modification to fit . I have heard for the samba pipe that works good with engines like your type but still from what i have read - heard no one has ever tried on a ts motor. very expensive to buy and try by myself....as for the ignition i use the ts fan cover and the setting is now at zero degrees .some other ts guys told me to turn it to +4 degrees with 100 unleaded . I do not know still never tried this . (sorry if my english is bad)mate i aint got any experience in the on road either its all come from mike1970 and fg-info.co.uk and guess work trial and error,,im with you i want the best car i can afford with what little money i have
my engines a 23cc oddified zenoah with red race ignition and a stock wt 668 carb running a oddified ecu with 15 different map settings im using a stock fg pipe at the mo and a carbon filter the cars got over 6hp and will rev to @22-22500+
havnt got round to testing it with the new ignition or the new gears yet but its going to be great fun when i do lol
got a nice big wish/todo list as well
got a wt771 chokeless carb to fit
want a new pipe samba 7 titan god knows how im getting the cash for that but i need 1
rear hydros
some evo carbon bits
plus lots more
