Need help with battery for hpi Baja 5b
MrXD
Ohio
Hi everyone, I'm going to be using LiFe Batteries for my baja 5b (gas) for the receiver and servos, would a 2200mah 6.6v be sufficent for it? the battery box just not have the room in it since its still moulded for the 5 cell hump packs, I was looking at a 3000mah but its size it just fit would be really tight after some modding to the box lid underside. I really don't want to mess with lipos and I feel safer using LiFe batteries for now. If it helps I am using a Hitec d845wp Steering servo and I haven't got my throttle servo yet, and this baja is the new sbk model if that helps. If I use the 2200mah battery what kind of run times you think I could get? Thanks for any help you can give, much appreciated.
yes a 2200mah life battery will be fine mate,
i run a 1600mah life battery in my shorty baja sandrail and that will last an afternoon of bashing,
just recharge before your next outing, or get a couple so you can swap out batteries if one goes flat while you're out,
thanks a million, just what i needed to hear
I use this one in my KM baja because using the stock servos for now. It's a tight fit but it works. https://www.ebay.com/itm/1332041796...sQB_azbSfC&var=&widget_ver=artemis&media=COPY
thats the one i was looking at to get but the measurements is really tight for the battery box, but the 2200 will fit easily
