Need help with this...
Beva_bog
Yorkshire, UK
I've bought a second-hand full alloy Leopard style RC. All is good except a couple of niggles. The ball joint from the wishbone to rear hub keeps 'popping off' under hard cornering. Any ideas? Do the bushes need replacing or is there some other adjustments I need to be making?
Any advice you can share would be great!
Also, can you share set-ups for general bashing? It's a little lively on the backend sliding round often and also rolls a bit. Cheers!
50908
Crafers South Australia
R.c Car online has those on special quite often pic up some new ones
New pivot balls the aluminum wear quicker then the plastic in the mean time put a washer so they don't pop off
That will do the job for now (y)
Is it two wheel drive or 4wd? Change the tire to less aggressive tread so as to not hook up as much .
I Find iF you going into a corner tap off on the gas a bit may help rolls. may be driving style . Take a few more pics let's see more of it(y)
