Malcolm Macleod
- Australia
Took the Baja out today and before I could get started had problems with steering. Yesterday it all worked fine. When I steer left it is ok, but when I steer right it starts to go right (1/4 turn) but then swings back left. Not sure why. cant see any changes on the Handheld. Batteries seem OK. Only thing different is there is a bit of leaking fuel that the servo is sitting above I think leaking from the Carbie. Not sure if this fuel would effect things. The Servo seems to move freely and I cant visibly see any slippage on the vinyl gear.
Can you help.
Regards Malmac
Can you help.
Regards Malmac
