chevyderek72
- Reaction score
- 0
Ok i got a few questions, i think i may have got the wrong carb or something. 2 things i noticed about it, there is a metal piece between the carb and air filter. It extends out toward the clutch and has a brass piece on it with a nut, almost like a piece to help hold the motor.
And then the throttle on it, it looks like its for a goped with a cable. Its straight up when the throttle is closed, and when you open the throttle it go forward up to the choke, and the choke would get in the way of the throttle linkage.
Did i get the wrong carb, or just the wrong pieces?
Also do they run the motors before they send them out. My clutch shoes look a little worn and i smell gas in the carb.
