Check your factory servo number on the losi sight. Most of the newer models were good for high voltage. If yours is, get the killer bee high top lid, and the 6000mah battery made for it.
if i installWell that blows lipo out of the water. Must be an older one.
battery box dimensionbattery box dimensions?
yes, then you can run a lipo or life. I think you should replace the throttle, as the stock prob wont last that long anywaysif i install
Hitec D-845WP 32-Bit, Multi Purpose, Waterproof, Steel Gear Servo w/Free DDM Alloy Horn - ht845
for throttle can i then upgrade battery? both will be same servo then
Only one servo is high voltageyes, then you can run a lipo or life. I think you should replace the throttle, as the stock prob wont last that long anyways
