Fidelity101
I have the older Losi 5ive T (with the 26cc engine) and I found a near new condition Dynamite 29cc 4 bolt motor that I plan on installing along with a 20T pinion.
The problem I'm running into is finding the right components required to complete the installation. I WAS planning on pulling the Bartolone Clutch housing off my very old and well used 29cc 2 bolt CY motor and bolting that up to the new Dynamite (CY) 4 bolth engine until I read the fine print on Daves Motors website: "DOES NOT FIT the four bolt 29cc Dynamite from the RTR Losi 5IVE SCT w/AVC" Does anyone know WHY it doesn't fit? I am waiting on a puller tool in order to remove the clutch assembly, otherwise I'd look for myself.
Is it even worth going with the Bartolone clutch housing, clutch carrier and mesh plate or should I just leave well enough alone and use the stock parts from the 26cc engine? I already have the Bartolone clutch housing and the mesh plate, so the only real cost would be purchasing the clutch carrier for $40 (found one used).
Will the clutch need to be upgraded as well or can I reuse the stock clutch from the 26cc Dynamite 2 bolt (CY) engine on the new 29cc 4 bolt (CY) engine? I have a few spare 8k rpm springs and shoes which have been pulled from used motors so sticking with the stock clutch setup would definitely be the cheaper option vs. purchasing the Vertigo clutch with hex drive...which looks awesome.
http://www.davesmotors.com/vertigo-100652B-hex-drive-vented-clutch-bell-for-losi-5ive.html
Maybe this entire process will be a waste of time for a small gain, but I have the stock 26cc engine running well and it's a rocket ship with the Samba tuned pipe I picked up. I figured I'd step up to a 20T pinion because I have LOTS of room to drive the vehicle and I'd rather have a bit more top end...currently capped at about 37mph on grass and 40mph on pavement. I figured the 29cc engine would give me that little bit of extra punch to keep torque high while also helping with overall performance as compared to the 26cc.
So lots of questions here and I apologize in advance...I want to be able to order the parts I need and be able to build everything in one night without realizing that half of the parts won't work together.
Anyone with experience dealing with all of these components...your advise would be greatly appreciated.
