Hello everyone
Im new here and new to 1/5 scale buggy's
I've bought a FS racing 1/5 petrol buggy
I've mixed the fuel at 40ml oil to 900ml petrol *tank was not full but would not take any more without having to tilt the buggy* the mix should be 25-1 by the manul
I've then primed the Carb intill there was fuel in the carb bulb + a small air bubble
Choke on my carb is in the *down postion*
I've pulled the starter 3/4 times SLOWLY to allow fuel into the engine *to give it some oil*
I've then pulled the starter 3/4/5 times fast/hard with no engine POP or choke POP * i don't understand that part* *engine not trying to start at all
I've try again to check for fuel Primed + try again to choke pull the starter + unchoke and the engine still would not start
The fuel is afew months old..., It does not smell like varnish
I've taken off the carb to check for the Gasket is the correct why around, I've checked the fuel lines are the correct way around
I've taken out the spark plug and checked for spark *it sparks every pull*
With the spark plug out, The spark plug has ignited some fuel while at the spark plug hole
I've Taken out the spark plug flipped the buggy upside down to check for flooding, + pulled the pull starter *very very small amount of fuel came out*
I've pull the started with the spark plug out to check for fuel spray *there is a very small amount fuel spary coming out of the cyclinder*
Im at a lost at the moment, its read alot of forms about to common problems
I know the problem can be
Bad fuel
Bad spark plug
Air leak
Thanks Sonny
Bad fuel
Bad spark plug
Air leak
Thanks Sonny
