for you mtxl owners. Not sure if the mtxl chassis would fit the dbxl but if it could, you dbxl guys are in luck, but it's likely pointless becuase dbxl can't fit a big bore like the mtxl
Fort the dbxl and mtxl? I dunno, but for this, it won't work because the mtxl uses spacers for the center diff and what not, so rcmax integrated it into this chassis instead of separate shims. So the dbxl doesn't use these shims so it wouldn't workIsn't it the same chassis?
It is. Not sure why he chose to release it but maybe Mike wants to keep the mtxl platform alive.Wierd coz thought the mtxl was discontinued?
I'd still consider one if I had a DBXL still. The stock chassis has as much rigidity as an overcooked noodle that's bean beaten with a tenderiser. I bet the Crazy Stu chassis would still be cheaper though and equally as good as this one.for you mtxl owners. Not sure if the mtxl chassis would fit the dbxl but if it could, you dbxl guys are in luck, but it's likely pointless becuase dbxl can't fit a big bore like the mtxl
the one they sent botajell was a pre production model, he said they sent it to him to make sure the holes were spaced properly and the measurments are correct. so he said if they are, then they will begin productionSo any idea when they will be dropping this? Was just all over their sight and found nothing for the mtxl that isnt something that fits either everything losi or also fits the dbxl.
