New RedCat PhatShaft shocks.
I am using HPI shock oil, not sure if it is silicone or not. Actually mixed 20 and 40 together, hope that was the right thing to do. And RAMTech 20% stiffer springs. I'll get some video as soon as my grass area dries out from the flooding.
Phatdad-RC Bajampage Shock kits are now in stock at RampageHopUps:
PhatDad-RC Shock Shaft Kits - 2 pieces of Hardened Heavy Duty shock shafts, with baja adjustable pistons (HPI #85412), HPI shock caps and lower rod support. You supply the Rampage lower ball ends, shock body and oil.
What size O-ring do the shafts take? Just standard HPI O-rings seem a little tight and the HD shaft rings are huge in these. I was going to order a big pack but I don't know exactly what size they are.
standard HPI rtr o-rings work perfect. I use a little silicone oil on the o-rings and shaft before I carefully push the the into the lower cap.
