JoshT
As the title says I'm new to RC, and have a brand new KM Baja 5B. Its the KSRC-002B Wild Grey from KingMotorRC.
I've read and been told that the first thing I need to do is go through everything and make sure all bolts are tight, and that the diff is full. About to order some 3K diff fluid, and will start tearing into and checking out everything this weekend. I would go to 10K fluid everyone seems to like, but want to get used to it in mostly stock form then work up. This buggy comes with the outerwears (KM brand) on the pull start and the filter. Bought shock outerwears to go with it. Plan to add the mesh, and maybe outerwear, to the case vents since I'm going to be halfway there with the diff.
Right now I'm thinking I also need to get a kill switch, but I don't know which one, and will probably go ahead and add shock limit straps to make them last as long as possible. Is there anything else I should do/add while going through it? Want to save most modding and upgrading for as things wear out and break. If I'm missing anything or should think about adding anything please let me know.
