Non-starter!
ClydeBuilt
Glasgow
My baja ran fine last time out, but next evening...zilch!!
Theres a spark and fuel and plenty of compression, but it just wont start, are there any 'Go To's' for non starters?
You probably flooded it. Take the plug out, turn the buggy over (make sure debris will not fall in the top of the cylinder) and pull it over 10-15 times, dry the plug and retry without the choke.
Clyde if you page through the engine thread thereis a shed load of info there for non starters.If the solution isn't there then the problem doesn't exist!
Good luck
J.
