Now I own a MT
big ed
Picked it up an hour ago. Ran it up and down my street to c how it ran, it was puffin out alot of smoke and had no power and I jumped it up the curb into my front yard and wheel came off. It already had gas so I checked it and it look like somebody didnt change there oil in a car for 30,000 that how black the gas was. Hopefully this isnt the start of another nightmare
the wheel came off couse they don't have knurled ends like the baja's. you can use "blue" loc-tite or simply get some darksoul,cat-5, or hpi wheel nuts. works a charm. the smoke meens nothing. could simply be the type of oil or that its been in the tank too long.. not much too that.. it may appear to run kinda slower. but remember. it 4wd and those mt tires are super heavy. put better tires on that thing and you will smoke all 4. sounds like your setting your self up for a nightmare. pretty basic stuff, thought i was going to get some pics? :D . all the info you need to wake up from your nightmare is here on the forum.
-upgrade your shocks, hpi hd's
-ditch the stock shell
-pull the cinder blocks out and you will run faster(prolines and rockstars)
-a ported 27.2 will scream!! not enough power to break parts but enough power to crank out some rpm's
-black side mount dom, :D
with some gearing a 5year old will do laps around that 5t.
before you run it you should do all the fixes it needs like green loctite all the dogbone pins, centre all the dogbones with 1/2 a decidamp earplug in each cup, ditch the stock th/br servo...check out some of the threads on what you should do.
to get it to run better pull off the long exhaust stinger and pull the guts out of the can and then tune the carb...and get some good gas and oil.
If you run these straight out the box things will go wrong in a hurry
Lizardking said:
25:1 my gas is light blue..
Thats what I run also, its good for break in too. Rich is good on your first tank. The wheel nunts need to be locktite or 5g nuts or even a nut with an o ring ar a knurled back side
I got this slightly used. everthing was done by previous owner. I was just venting a little, I have a 5t and run 32:1 in it. I am definitly puting the upgrades and dumping the sludge out of the tank. I just wanted to run it to make sure it wasnt broke. There is alot I don't know about this rampage so thanks for all the advice.
