Pollishman
If I want to order a different head or gaskets, what motor is the KM 30.5 comparable to so that I can order parts for it?
get your self some of the DDM reinforced gasket set so if and when you tear it apart you have some good gaskets to rebuild with, a better plug wire,and reshim the coil make sure its @1mm,the ngk plug gapped @.027,
if you want the intake upgrade make sure its mating surfaces are clean,
one thing i like to is not tighten first the screws and bolts, but untighten then retighten make sure they are not ,frozen on, by over tightening or toooooo much lock tight.
also after running mine on the grass i realized i needed to seal the engines fan/flywheel area it got loaded with grass and leaves,so outer wares and some screening for the underside of the engines fan intake,i use a rb fan filter system.
and get a spare pullstart you never know when you will need it,
i like them i use them on my bajas,Ok so my parts list continues. Looking at the rb fan filter is it good? I figure with that and of course outerware for my filter all is good dirt wise? My area is dusty and grassy. Lots of small rocks..
becaureful in small rocks/gravel make sure your engine is sealed as they are harsh on flywheels and pistons if ingested.
