Polarized Castle Connectors
Hi Guys & Girls,
A quick question, if i could have your help and/or options. Has anyone else found the Polarized Castle Connectors (Male / Female) are quite hard to push together and twice as hard when trying to disconnect them. ???
I have just changed over to the theses connectors after getting a XLX2 and 1100kv I have to use a set of grips to pull them apart ? is this the norm/common or is it me ?
Can anyone suggest a way to loosen theses connector or do they need Electrical Contact Grease maybe ??
I await you suggestion or may i just have to change over to a different type of connector. ?
All the best GingerfoxDBXL-e2.0
Yes i used them once and they were extremely tight, they're expensive, and overall i just don't like them.
Also they're not anti-spark, which you need with Castle ESC as they don't have anti spark built in
Anti-spark is deffo needed for 6S+ power systems
I switched to QS8 anti-spark and never looked back
tight is good won’t come unplugged when running, however you could make them looser by tightening the gaps between the male end prongs (split into 4 pieces) if it’s really that bad… but i wouldn’t recommend it
