Figured I'll start a thread for my Zelos 48" catamaran project that Ive had few years. She tossed the cookies in the original Zenoah 300pum a couple summers back(assumed I sucked in some sand in the wide open v stack)bin a flip over. So replaced the engine with a Gizmo motors GZM 30+ full mod with a billet block. Added the Bonzi sports "cool head." Also replaced the weak stock clutch with a billet unit from Bonzi Sports along with their tuned pipe. Swapped out the stock 3 blade prop with an ABC 2 blade fully balanced and sharpened copper beryllium speed prop. Added a pulse line into the carb insulator block to be able to run a water pump so she stays nice and cool at idle while tuning or idling in the water. Currently still running the Spektrum electronics. Will be swapping out for futaba soon for finer adjustments. Only things I'd like to change at the moment is the electronics box out to a sealed unit and swap the factory throttle rod out for the cable setup.
Running factory carb settings and running my vekta mix @ 25:1 castor/c12 more vids to come soon.
