Problem with drive cup rampage mt
Novemone
New Member
Hi guys, anyone know what a good replacement of a drive joint cup for rampage mt?
My stock drive cup was broken yesterday after have a jump with my rampage mt, im worried it will break again if im still use stock drive cup
Please help me...
Thanks..
Sent from my iPhone using Tapatalk
Re: Problem with drive cup rampage mt
Only options are the stock drive cups. You can make them stronger with sleeves tho
Not sure if th mt comes with them, but when one broke on my xb...
I replaced the diff cup with redcat "hardened" cups, I'll have to look up the #
Anytime dude. Sucks we have to make them tho as the baja ones don't fit. From what I got out of it its a 20 id tube I need
I went to home depot and found type "L" copper precut pipe.not type"m" its got a thicker side wall.the diff cups fit perfect all u need is green loctite or epoxy to hold them on.it comes in 2 foot lengths for $11.u could make 3 complete sets out of one piece.
How strong would this copper be as opposed to the steel tube?
Its pretty thick i cant see them break apart.go to home depot bring a diff cup and see if u like it.i believe there shouldn't be a problem...
They should but type"L" is what u want.just bring a diff cup to check fitment.its a solid piece it should just fine if u do get it use a pipe cutter to cut up the pieces.makes nice clean cuts.if u don't have one pick one up there cheap.it will save u alot of time...good luck
Check out my thread on "diff cup splitting", in the xbe general section carbon tube is the way to go, cheap and easy. Works well and is very light.
picture.php
