Problems with the idling after adjustment of engine
waqr
Sweden
Hi everyone!
I have a big problem that I can`t solve. It all started when I moved the engine backwards a couple of millimetres. The problem is that I can`t get the idling to go down except for if I adjust the servo with the radio (move the servoarm back). But when I do this I get another problem and that is that the servo the can´t give full throttle (because the servoarm is to far back)
How can I solve this?
I am running the Hitec Agressor (the one that comes with the FG). How do I set the end points and servotravel with this?
Pull the throttle servo horn off. Turn radio system on. Center the adjustment knob on the radio. Put servo arm back on with the throttle closed. From there you should be able to get wide open throttle & have an idle.
and you might need to adjust manually with the stop screws as well .. but lookers suggestion should work
Good to hear! Enjoy that beast!
Just a quick tip. If you rear lower ballends strip out of their turnbukles replace the 32MM turnbuckle with a 39mm. $20 to do all 4 and you're set!
