- Long Island, ny
- Thread starter
- #61
Update time... had a massive exhaust leak from the gasket and of course I stripped out the bolts for the exhaust so ordered a new kit... started prepping the body for the wrap
1. Took the body off cage
2. Cleaned and degreased inside and outside of body and then removed decals using goo gone to remove excess glue.
3. Sanded the body down. (Noticed cracks by the cage mounting points gotta figure out a fix for that.)
4. Heated up the body and tried to push out the dents (didn’t work out so well)
5. Sprayed body black as a backer for my black wrap I’m not expecting to see much of the body when the wrap is done, but I don’t want to see white or green in the seems between the stickers.
Also sprayed the pull start with graphite spray because it wasn’t engaging the flywheel and then noticed the flywheel is missing some fins :/
