Try the bag over the filter trick to act like a choke
I bypassed the kill switch w/ same result
The pulse holes look like they line up
I’ll put a new spark plug in but I took the spark plug out and sat it on the cylinder and saw spark
I got rid of the fuel quick disconnects and swapped the fuel lines. I have not checked the clunkFuel quick connects? Dirty clunk? Swapped the fuel lines?
If you go that route, don't waste your money on that POS. Its a total dog. I'd get an rcmax 40gt or on FB you can probably find a decent deal on a lightly used 46 rcmax, I've seen a couple come upKind of considering getting the obr 48 and a killer bee and calling it a day.
I just got a 34cc esp zenoah from ddm and the killer bee kill switch. I was looking at the obr and then realized how much I’ve spent in the past month on this rig and wanted to throw up. I’m gonna get it running and then hold off on the build for now and just fix anything that breaks. Christmas is coming up and I’m about to hut my slow season....If you go that route, don't waste your money on that POS. Its a total dog. I'd get an rcmax 40gt or on FB you can probably find a decent deal on a lightly used 46 rcmax, I've seen a couple come up
Mmmmm for the same $$$ could of had an obr 34 reed long block only extra you'd need is a shroud $12?
Damn man, I don't know that I've seen these kinds of starting probs. Once you get that bolt out and your ignition back in place, try spraying around the isolator block and carb with some WD-40 while you pull to see if it will at least sputter. Could be that the carb gasket is split and causing a leak. If the gasket is toast, the pulse from the motor won't pull any fuel into the case from the carb, but will instead be vented out.
Just a thought.
My new goal is to be able to run It for a full tank of gas without losing or braking anything for now and then resume the build after the holidays once I have disposable income againSounds like you have appeased the rc gods for now.
The clutch housing for my g340 didn’t come with a screw hole for the gear mesh bracket. Does anyone run without one or should I drill a hole in the housing?
