Q & a
GEZZ
How long will the Battery last in the Baja...........how often would you change the oil for the shocks
Depends on the capacity of the battery(1800 wont less as long as 4600)
put a fully loaded battery in your car and drive until it go into failsave,
then u know how long it goes.
The shocks i only do when i see that my wheel jumps.
Do you mean last from charge to charge or last for the life of the battery. For the life of the battery, usually around 100 charges with a NI-MH.. You will get allot more with a li-po pack.
If you are running the stock setup on your shocks and don't like it very much, you can then change it to 20wt in the back and around 40wt in the front. This is were i like mine, but everyone is different.
Chris
