My Previous try at an RC trailer failed (link below) so i did a little more research and came up with this. It is a QuitKat bicycle trailer that is supposed to haul 100lbs so up to the task for (1) RC, fuel, batteries etc.
Lumina XL Motorcycle Trailer aka RC Hauler
QuitKat Trailer Build Info
** Excuse the mess. I am building and reorganizing the garage so a small tornado came through.
I will be going to the desert over the holidays and wanted to bring one or more of my RC’s. A lot of killer places to run an RC can only be accessed via a motorcycle. So, this is “Test” and if It works well enough, I can also use it at home locally to go to Parks and valleys that I can run a 1/5 scale RC.
Because this is a “test” I just used a scrap piece of 3/4” plywood for the top platform.
To give a bit of strength I added a scrap piece of 3mm Aluminum plate.
For the quick-change mount from my previous homemade RC Work Stands I bought a 1” Floor Flange, 1” to ¾” adapter and bored out the adapter to accept a male portion of the Axis RC Swivel and Hitch Pin. I took the other male Axis RC Swivel that normally accepts the Top Plate and drilled a new hole for the hitch pin. This allows any Axis RC Top Plate to be used and in my case this is for the Losi 5T 1.0/2.0, Kraken Vekta(s) and Kraken Vesla(s).
As you can see, the black aluminum plate there are an additional 6 holes drilled. This trailer will only hold 1 RC at a time. The quick-change mount when in the center works for the Losi 5T 1.0/2.0 and Kraken Vesla(s). The Kraken Vekta(s) have a different mount for the chassis type so in order to have a Kraken Vekta center on the piece of wood you need to move the mount forward.
To mount the plywood to the trailer I went simple and cheap. Everything was left over from house projects etc. In the front, i used 1/2 “ EMT Pipe clamps with hitch pins. In the back to access the milk crates, I used 3/4 “ EMT Pipe clamps and 1” PVC pipe to make a hinge.
Inside of the QuitKat Trailer I used two of my milk crates from my previously failed trailer build. They can be used for batteries Transmitter cases, Tires and ?? whatever else.
For fuel I mounted one of my RotoPax 1gln jugs on the luggage rack. I’m not sure how long a gallon of fuel lasts but likely longer than I can concentrate controlling a 1/5 scale RC.
The Yamaha TW200 is about a fast as bicycle so the wheel should be fine. If it doesn't work out i have a spare 18" rear wheel from my Honda XR400.
