rally chassis axels
easy
Ontario Canada
guys do the axles on the new gen rally allow us to use the fg square type wheels??
what do we have to do to convert to use the fg style rims ??
If there is no squares on the rally chassis how to convert and is it possible.
Can we install the hydrolic brakes on the rally chassis??
thank you ....
The MCD shaft brake is the best in the 1/5 world, installing hydros would be going backward. If anything its too good and needs to be softened up a bit. Although if you wanted to play with the brake bias then its useless aqnd hydros are the go
