- Queens
ring is probably seated better. takes time for the ring to seat.Why would the engine with more use have more compression
Yep.ring is probably seated better. takes time for the ring to seat.
Depends on motor, if it's a stock rovan motor I wouldnt run anything more then 19/55, if it's a modded motor like 34 reed or esp 34 , then it would be fineWhat do you guys think of 20/54 gearing?
