Standard HPI filter all day long. That thing you’ve posted is garbage.Guys should I use the standard baja filter or this https://www.davesmotors.com/High-Flow-Cup-Foam-Air-Filter-for-CY-RC-Engines-270-024000?sc=12
thats garbage. i wouldn't do either, i say tgn easy clearance with a tgn redneck, thats what ive been running and its awesomeGuys should I use the standard baja filter or this https://www.davesmotors.com/High-Flow-Cup-Foam-Air-Filter-for-CY-RC-Engines-270-024000?sc=12
I use high temp sealantYou guys put loctite on carb bolts?
How’s those builds coming alongI use high temp sealant
