@dougstar ??....i looked after my engine blowing up quiet well thank you even cleaned it up after I was done wrecking it?
You should notice a bit more power over a piston port engine. (Depending on how it was ported) longevity is t really a factor. It's more or less the same engine, just different induction system. So if the builder did their part right, and you do your part right they should last the same. If your rules allow it, I would reccomend a reed engine, but there are several very stout piston ported options as well.I have a big question. Are reed engines worth all the extra money? Do they last longer? Thanks in advance.
So is OBR a safe choice?From my expirience reed engines have about 20-30 % more power ( as Sean said it depends on the builder ) they also have more power in the lower RPM;s and the power band is smoother so it is more controllable. I could be wrong also so ????
umm yes!!!So is OBR a safe choice?
that kinds says it all !
This was my obr 30.5 piston port , granted my truck is light but even that little motor hualed ass!Can't go wrong with obr ?
You got a sticker??? Wtf! Never again!!Can't go wrong with obr ?
Wait a month I'll have a video out. Its a suprise?I need a motor for a heavy 5ive 1.0
It had a obr 34 ss in it. I don't need a 800.00 motor for weekend racing. Was looking at the esp 34cc. From ddm. Any thoughts??
Definitely. I'm in no rush for a motor.Wait a month I'll have a video out. Its a suprise?
Holdup, you took the 34ss out? I'm sure the esp34 weighs near same if not a bit more.I need a motor for a heavy 5ive 1.0
