Reverse clutch?
No premature engine wear. If you run this on a stock engine, without a high RPM spring it'll bog like hell. Other than that, there's no real down side.
Guantanamo Joe said:
I had heard about this before- is there any down side to this? Premature engine wear? Seems if it is so much better, then trucks would just come this way?
Can be a lot harder on drive line parts as the clutch has little slip and harder engagement.
