Right top end of motor striped.
rcspeedmart
Atlanta, GA
The right side of the motor threads is striped where you screw the pipe into the motor so the right side of the pipe will not tighten down. Is there a fix for this without having to change the top end of the motor? I have tried the next up size screw and it will not fit. Any help would be greatly appreciated. Thanks.
You can use a Helicoil.
STgXKTosflUG-2JclM3L5u86dd8aohhz8_Hdh8VHY-6Jz3LzZrMa3vcrhC-UMf54pxPujECpWzCIVH2rdClPHrtrD5Nb6K9kDTJdXLqwq2139HJVyb3zCr59nnvZoTOBTe6dltRuNZuKjcelbVeHTmkSJU8fR3IjgD7ws5ne5qmvt6Dq9qQ50jSg_fgb4HDqUhj_V02-lTwJi0-i-0ug3_oJlO3Gy3_Q-QdXTZVSctStPJJwr_qiCQKvfncqxW1mSrBG7bHEgoY-wK7N4KPePFQI8xIOKxIVZP6IPqW96asLmyvnlokt19QjuhP7RYH_l9VQqbIex88qY0nP7mwQPFe03tA
Thanks so much rampage they even have a video showing how to do this thanks once again.
[ame]
[/ame]In case anybody else need this information.
You would need an M5 kit. Unless you plan on doing this alot, its almost cheaper to buy a new head and upgrade to 28.5 while you are at it.
