Bandit2013
- North Carolina
The Rovan limited edition 360A (all aluminum) seemed like a bargain compared to the King Motor 002 I rebuilt with upgrades. The one in question is the blue one on the right. Made a few slight mods to include upgraded RCR brakes, Turtle Racing HD clutch assembly and black magic gears 18/56. Also changed the tires for off road use since it came with road tires.
Lots of fun while it lasted. Broke one of the upper ball ends on the left front side. No big deal as I had spares available. Engine felt like it was getting slower, performance was not what it was. Not sure if this had any relation to change in fuel oil from the local brand (Lucus semi synthetic 2 stoke to the Maxima Castor 927) or if the clutch was going. The Castor 927 did seem to make a difference.
Decided to inspect the clutch and replace if necessary. Clutch had plenty of meat on it. Spring was tight. I changed it to see if there would be any performance differences. Also found the bird's nest under the engine cowl so cleaned that out. Did a slight mod to the engine cowl for easy cleaning purposes but it will still force the air from the fan over the engine head.
Decided to try the 16/58 gear set for smiles and grins or will it be tears and frowns. Tuned up the carb for better performance. Seemed like I needed to make the mix richer for the high needle. Had it all going well, I thought. At least for one tank or most of it until it died. Engine still rotates ok but compression on the pull feels a bit light.
Next day, cleaned it up with compressed air. With the mod to the cowl that was easy. Still have plenty of fuel in the tank to fire it up. Noticed the fuel was pooling around the spark plug on the top of the engine. Plug was tight. Engine would not fire. Removed plug and had no spark. It did not look very good either. Perhaps I was running it too rich. Changed the plug and got it to fire up. Then again, the fuel started pooling around the spark plug. Cleaned it off with compressed air since the car was on the bench I use for break-in and other things. Fuel was leaking out on the top of the engine at the seam that runs down the center of the head. It got worse while the engine was heating up. I do recall hearing a crack or loud pop when I installed the spark plug before this issue cropped up. May have cracked the casting. Not sure if the engine is the dual ring version. It is that chrome plated Rovan 36cc (came with the car installed). The other car has the same engine which will be coming out of it soon enough to make room for something different, so I have a spare. Need to look into the fuel leak on the head to confirm if it is cracked or is it bypass around the spark plug.
I am still new to this hobby. I was not sure what to get when I ventured into this. Rovan and King Motor were something inexpensive to start with as well as offered plenty of parts. The first one I bought was an Exceed Barca (it is the monster truck converted to a buggy, clone to the Red Cat Dune runner). Did not think this would be a good basher but it turns out to be one that I have yet to brake. It has a CY 32cc engine (I think, but it could be a clone of a clone). To be honest, I think it is much faster than the Rovan or King motor but may be due to lower mass as it is 10lbs lighter at best. I took the picture after fitting the aluminum roll cage at work (had to cut and bend the front section as it did not fit correctly since it was designed for the dune runner that does not have the dual steering servos). I did not have the exhaust on the engine. Yeah, those are the DDM wheels sized for the baja rear on all 4 corners. I have launched this one into a row of trees, took out my front yard light with it. Everything has held up thus far.
Now I have a better understanding what this hobby is. Expensive. But at least I am having fun.
