davehour
- Puerto Rico
Well it’s pretty much a complete engine minus coil..flywheel..carb and intake..ETC
So everything else needed to complete the engine is taken from the Rovan 36cc?
Thanks.
Yep in fact that’s exactly what I did with the exception of the DDM billet intake that comes with the nylon gaskets…hate the POS intake CY uses but there are 2 little things for the kit you’ll need which is wrist pin clips and wrist pin I think…anyway read the description before you order to make sure…I can’t afford those $1500-$2300 engines so if your on a budget this is the best bang for that hard earned buck..IMOSo everything else needed to complete the engine is taken from the Rovan 36cc?
Thanks.
I will be replacing the entire engine including the carb and air filter assembly. Not sure about the pull start. If it is not as crappy as the one I had on the KM30.5 I will change it. How much of a clone is the Rovan 36cc engine? Did it really come with a Walbro carb? Rovan claims the Walbro 1191`is the same as the WT-1107. I assume the flywheel and fan cover would fit with a rebuild kit. However, there is that chance nothing will fit when reusing parts from the 36cc. I went for a complete engine from DDM.So everything else needed to complete the engine is taken from the Rovan 36cc?
Thanks.
Well CY engines are just very low quality and the carbs are a clone of walbro from what I’ve been told but how I’ve been doing it is run what ya brung til your tired of f$$king with it and upgrade…I never thought there could be such a difference between CY and zennies but you just can’t beat the Japanese when it comes to 2 strokes hell any small engine and they run great…funny iVe got 2 36’s sitting in a box and one only has like 2-3 hrs of run time…just keep them around in case but Think im gonna build a shitshow basher for my buddys to beat…lolI will be replacing the entire engine including the carb and air filter assembly. Not sure about the pull start. If it is not as crappy as the one I had on the KM30.5 I will change it. How much of a clone is the Rovan 36cc engine? Did it really come with a Walbro carb? Rovan claims the Walbro 1191`is the same as the WT-1107. I assume the flywheel and fan cover would fit with a rebuild kit. However, there is that chance nothing will fit when reusing parts from the 36cc. I went for a complete engine from DDM.
https://www.davesmotors.com/ESP-Modified-Zenoah-G40RC-Engine-Complete-HPI-Baja-Losi-5ive-DBXL?sc=12
Will figure out what to do with the Rovan 36cc in question in my case.
Here a video of that engine in my Losi I took today in the snow…she starts bogging a bit with the extra ten lbs of snow in the chassis and a soggy air filterWell CY engines are just very low quality and the carbs are a clone of walbro from what I’ve been told but how I’ve been doing it is run what ya brung til your tired of f$$king with it and upgrade…I never thought there could be such a difference between CY and zennies but you just can’t beat the Japanese when it comes to 2 strokes hell any small engine and they run great…funny iVe got 2 36’s sitting in a box and one only has like 2-3 hrs of run time…just keep them around in case but Think im gonna build a shitshow basher for my buddys to beat…lol
You need some of these to get through the snow. Only kidding. Think they are more novelty. Since you have 4WD, you need two sets.Well CY engines are just very low quality and the carbs are a clone of walbro from what I’ve been told but how I’ve been doing it is run what ya brung til your tired of f$$king with it and upgrade…I never thought there could be such a difference between CY and zennies but you just can’t beat the Japanese when it comes to 2 strokes hell any small engine and they run great…funny iVe got 2 36’s sitting in a box and one only has like 2-3 hrs of run time…just keep them around in case but Think im gonna build a shitshow basher for my buddys to beat…lol
Ya it will…my Baja just has G320 with ESP race ported cylinder and runs greatI had a good opportunity to run the Rovan today. 58/16 gears, 7k clutch spring. New spark plug. I was running way on the rich side previously, so I did make some adjustments to the carb yesterday morning. Started at defaults. I did not have to make any adjustments today and the engine ran without issue. No leaks around the spark plug or along the head casting seam. Ran the tank dry (almost). WOT, the rear loses traction. Damn Rovan tires. Thinking on the Duratrax lockups since the viper and others are sold out everywhere. What I have now is just ok but they do much better than the stock treads.
I am not running any screens on this one yet. I did cut away the melted plastic on the cowl. I left as much as possible so there would be no forced air in the direction of the carb. I did not feel like putting the body or rear wing on the car if I needed to remove the engine if what I thought was correct and the head was cracked. Performed well actually.
If the Zenoah with 34cc stroker is more of an engine than the Rovan 36cc, I am not prepared for that but anticipating the grin I will have once I get the engine broken in. Most likely run the 18/56 gears with that engine. At least I will have an extra engine to use if needed.
