I am having issues with my newly delivered Rovan Baja; what has happened so far.
1. I broke the starter pulley from just a couple a pulls. (fixed that)
2. My ignition coil was rubbing the flywheel. (I fixed it by using an old business card I don't own a feeler gauge.)
3. Still no spark; I had no continuity with my multimeter from the plug wire to the coil. (I fixed the little spring that is not making any connection with the wire. I chose to solder it and shove it back into the rubber elbow.
4. Now we have spark but still no start.
5. I looked up here on this site and compared some photos and it looked like my carberator Hi and Lo settings were all the way backed out. So I set it to default Hi 1.5 and lo 1.25 turns.
I am at a loss for what is next for this motor; it doesn't start. I welcome any advice; I will search more through this site, but my brain hurts, and I am having trouble searching the right keywords.
Some side notes my power to my electronics is all good throttle and steering; not sure if that matters in the diagnostic part.
