91300zx
Picked up a baja 5b this past week and did the break in no problem. Got my low speed dialed in and it was ripping. All of a sudden it just started revving high and barely moving and the engine died on me. Fired back up in a couple of pulls but the high revving stayed. I checked the clutch and it looks fine. The clutch bell looks fine I think a little bit shiny. When spinning the wheels they would rotate in the same direction so I decided to pull the differential and that looks fine as well although when putting it back together it feels tight and the gears are some what loud. Sadly I spaced it out to check the diff when first pulling it out. Before I throw it all back together I am looking for any suggestions on what might be the cause or what to check for. I also checked for broken pins, wheels, loose screws etc and everything looks fine. Any help at this point would be much appreciated. Thank you
30.5cc flavor if that helps any.
