tim3
ROVAN LT 320 SHORT COURSE 1/5 32cc RTR 4WD
Older Thread-
ROVAN LT 305 SHORT COURSE 1/5 32cc RTR 4WD https://www.largescaleforums.com/threads/rovan-lt305.19560/
All info from Rovan RC.com http://www.rovanrc.com/1/5-truck/lt320-32cc-ready-to-run-4wd-short-course-truck-rtr/
• 32CC powerful 4 bolt Rovan sport engine with Easy Pull Start System, Walbro 997 carburetor and NGK spark plug
• 1/4 scale size 50KG RS-2050D all metal gear steering servo, and 40KG servo for the throttle and brake function
• Heavy duty full time 4wd shaft drive system with CVD drive shafts and steel gears throughout the drive train (no plastic gears)
• 3 HD metal gear sealed oil filled sealed viscous differentials (front/center/rear)
• High Performance 8000 RPM Clutch
• Wheel set (170x80mm) with HD 10 spoke bead lock rims with inner metal 24mm hex
• Fly-Sky GT-3B 3 Channel 2.4GHz transmitter computer radio with automatic frequency hopping digital system, 10 model memory, servo reversing, end point adjustment (EPA) , dual rate, exponential, auto brake system (ABS), model name etc.. No need to worry about having the same signal as someone else. Built in failsafe just in case you go out of range.
• 6V 3000 mAh NIMH Rechargeable battery
• Front and rear sway bars for great handling
• HD front and rear HD Plastic shock towers
• Foam air filter element set
• Aluminum clutch bell support
• Strong polycarbonate material painted short course body panels (4 pieces) are held on with a built in internal plastic roll cage.
• HD short course front bumper and rear bumper with rubber mud flaps
• CNC aluminum large-bore high volume oil filled shocks with 7mm shafts & threaded adjusters
• Full ball bearings thought the entire drive train
• Large 800cc gas/oil tank
• Dual HD adjustable front and rear disc brakes
• CNC 5mm thick aluminum frame
• Heavy Duty Steel Tuned pipe installed!
(NEEDED) 2 stroke gas/oil mix (25/1 ratio)
