Rovan Steering
Buggy Basher
China
I found the plastic steering bellcrank was broke. I ordered the Aluminum replacement. After putting it all together I noticed there is not much throw left or right. Are these things supposed to have short throws? TIA.
Just don't seem that the wheels turn far enough right and left.
Video wont post
Make sure the top spring preload adjustment screw is not jammed against the chassis pan. This was an issue with my Rovan when I swapped to an aluminum steering assembly. I had to run a shorter screw so as to get max spring tension preload yet not jam the bottom of the screw into the chassis.
10-4
