rx lipo?
rcpython59
minnesota
i got a 3200 2s lipo battery and i want to use it as a rx battery,will it fit,will it work,will i have to buy a lvd system? on a km ksrc-002 buggy
atom3624
Cold, wet, windy St Helens, U.K.
Simple answer is YES and NO!!
Check that your Rx and servos can take the higher voltage of 2S LiPo.
If they can't it's no problem.
Get a 6V voltage regulator. LRP do a 6V / 10A regulator.
Not cheap, but could save you quite a lot of money!!!!
Trebor
manchester...UK
why bother as atom says works out expensive,its touch and go with
the 6volt receiver batteries as it is, when fully charged can get to 7 volts
K....
rcpython59
minnesota
so 2s is safe?i will get a buzzer then for like 5 bucks off ebay.does anyone know if a dynamite 3200 mah 2s will fit in the km rx tray?
atom3624
NO !!!!!!!!!!!!!!
Some servos don't have a problem.
Some servos have a MAJOR problem.
Check your manufacturer's recommended maximum voltages before you connect - it might be for the last time.
I have Rhinos on my vehicles, and there are plenty of stories of incompatibility with the higher 2S LiPo voltages with these.
