sand paddles
i think a few of the Aussie guys tried this out. im sure one of them will chime in when they see the thread.
i don't remember how they said it worked out.
i wouldn't think that would be the case. on a full size sand rail, you actually run with about 20 psi(max tire pressure) for optimal traction. so if anything i would probably over stuff them and make them a little stiffer.
i would think that you would, but you would prolly have bigger problems afterwards... i would just trim down the foam inserts instead, and then you would get better forming to the ground, therefore better traction at dunes...
well cya! pm me if you have questions
