setting futaba to run digi servo's?
kryptonite5b
philipsburg pa.
ok, so i found the online manual, but im still stumped on the digi thing. is there a setting to switch if you run anolog/digi servo's? it says there is a "ppm" and a "hrs" side. but what is that? ive always run digi servos, but never checked to see if my radio is running on that setting.. kinda stumped
here is the manual, maybe some one can put it in "MY" terms
page 53
http://manuals.hobbico.com/fut/3pm-fm-fs-manual.pdf
PPM is for using any analog servos in the setup. HRS is ONLY FOR Digital servos.
HRS Has FULL Failsafe memory on the channels. PPM has to be reset everytime you turn it on, and it only effects the t/b chnl.
Be sure to double check how you setup any remote kill switch that is supposed to shut down when you lose power ect.
ok, so im running digi servos. (always have been):blush:.. when i turn my radio on it says "ppm".. the manual says that you must run ppm mode if using reciever R133F. and HR mode can only be used with an HR203F. but i have the R153F recievers. im assuming the the HR means high responce and the R means rediculous.. so with that info i am also assuming that i cant take advantage of using digi servo's? YES OR NO? GRR.
