Shen qui Bigfoot start up issues
Colchdan
New Member
I can’t seem to get any electornic power with my Shen qi big foot does anyone know how to set up my controller frequency please
@Colchdan In the manual for your controller there should be a section about how to bind it to the reciever. I am not sure what it is you are asking because you don't get to set the controller frequency. If you use a 2.4ghz transmitter then depending on whatever brand it uses a cpu and software to sort out your reciever from noise and other transmitters. One methods is using increasingly smaller windows where signals can pass though until only your recievers comes through. This happens instantly and it is polling ("hello my reciever are you there?") for the reciver all the time.
However none of this has anytning to do with your RC's power. If the truck does not get any power even if you insert a fresh battery and turn the truck on. Then you have a dodgy wire/connection somewhere in the truck. I would start by taking a look at the wiring. Has anytning snapped? Is there loose connections in the plugs? And then troubleshoot down to where the issue is like this.
