I've been using my truck fairly often for the last 2 yrs (ish)
When ive needed to change clutches, ive noticed the clutch bell walls are very smooth and shiny, will it make a difference running like that or should i buy a new bell?
Recently, the bell itself has also caused one clutch to burn out and a gear to melt, would the clutch being this old and used cause immense heat to occur??
Bearing in mind i have fitted a ddm torque pipe, a velocity stack and a new air filter
