Should i upgrade
webster
has anyone swapped out there stock plug wire and went to the craftwerks hp msd plug wire. i would appreciate any comments good or bad..thank you
I did and I'm happy with the result. The boot is easier to remove and reattach than the stock offerings, I bent the spring inside the stock one the first time I pulled it off for a plug check. My stock one was also poorly insulated, I would get a tingle if I touched the boot. No such problem with the craftwerks wire. All around, it's just better but together, the thicker wire looks nice, it'll probably be more durable over time, and the color options allow for a nice customization factor to match your ride. It was $13 well spent in my opinion.
