Silver Solder Brake Hub on?
KrashKrieg
N.J.
My Red locktited grub screw came out of the brake hub (again)…really messed up my brakes this time…
I want to semi permanently attached the brake hub to the Center Pinion (with the bearing and carrier plate in place)
As I do not weld, am I wasting my time doing this by dropping Silver Solder down into the grub screw hole?
My thinking is it should be strong enough to not come loose unless re-heated again to about 900
Yes I also realize I could probably accomplish this by using a stupid amount of locktite but would still have to deal with the grub screw...
I’d rather just use the locktite on the grub that easiest to get at and re-tighten / check…
Is your center diff mount plastic or allum? [some plastics don't like loctite]
If red loctite isn't holding the screw, either it's stripped or a serious heat issue..?
Is the problem bad bearings or the square on the shaft worn?
Too much play/slop in the brakes will bind the drive shaft. [and create heat]
When setting the bake, the grub screw shouldn't be too loose on full throttle.
The plates, if too loose will bind...they need to be set kind of light at neutral.
