Solved - DBXL 2.0 Center Diff Install Question
SerraAvatar
Problem solved - please disregard
Hi there, I thought I could install the center differential by pushing the center drive cups at both ends of the diff through the center mounting plates (indicated by yellow arrows), only to find out the center drive cup is larger than the opening. I ordered the drive cups marked as DBXL 2.0 (LOS252118) but clearly these will not work.
Has anyone else experienced this? Thank you so much for reading and for your input :)Cen_Diff_1.png
Nevermind: I used some elbow grease and was able to push the diff through the polymer mounting plate.20200803_203355.jpg
