Spectrum dx3e problem
dziurol
hello, I have a problem, all the time after the binding process, two LED lights - red and green still light on. I know that, the only green one should be on.
Next problem-Can I turn off and turn on the LED light from the radio (3 channel) , or I should have led controller?
because in my radio it doesn't works.
I have Baja 5t
let me see if im getting your issue correctly.
your trying to bind the rx to the tx, and both red and green lights continue to light up after the binding process?
i take it you have no connection afterwards?
now, if you want to use lights on the 3rd channel, they yes, you will need a light controler like the Killer RC unit.
yes, after the binding process both (red and green) still working.
throttle and steering servo works correctly.
