Speed testing
lords
well took the Dunerunner out today and checked out the new engine.
1 hour running temps was 140F..
on a Geko 101, it showing 39MPH GEARING:31,29,25,25
oh and lost a center dogbone pin..(no front wheel drive while checking for speed).
going to install the new center pin and then up the gearing to 35,25,25,25
just adding my 2 cents in the DuneRunner section
and looking for speed...lol
cold and windy out today...
ok redid the gears to 35,25,25,25 ..
had the better half take the video..it's her first time forgive me on this.
I have to splice them together.
we will get better...lol
top speed 43MPH 32 to 1 mix 30.5cc ported and polished
left it in 2 wheel drive for testing and boy as you will see in the video it just lights the tires up...
engine temp.145F. clutch temp after the run was 245F. elcon clutch set to 7500.
[ame]
[/ame]
hamster huey said:
I have a 31/29/25/25 on my 27.2 ONB TT. Ill see if I can get a reading on it.
41.5mph running a couple hours rich to the point I can see light smoke at all times from the pipe. 813 carb 27.2 onb, lightened piston, blah blah. P2W!
yes i do have to pick up a 813 carb and dump this 667....
lords you might wanna check the walbro wt-990 it doesn't have the internal accelerator pump like the 813, they say it's supposed to be better than the 813.
