Just a heads up on what to do for a low voltage failsafe. Off the Spektrum site:
Will a Low Voltage Fail-Safe work with Spektrum Receivers? - 12/28/2007 9:57:02 AM
Spektrum surface radios include a signal loss failsafe, but do not have a voltage failsafe. You can use the http://www.horizonhobby.com/Products/Default.aspx?ProdID=DYN2553 to build in a voltage failsafe. The Race Guard will kick in when the voltage drops below 4.0 volts.
