- Thread starter
- #21
small update to this ,
a tad stuck till some parts come back into stock, then i can crack on much faster,
plus had covid booster jab the other day that i had a reaction to, so cant machine anything till side effects wear off ,
but stripped all three diffs to give em a clean and get the blue grease from the outside and diff fluid that was in there gone,
all cleaned off and set out to make sure i had all the parts still ,
rear diff will be getting a front crown wheel, and centre diff will be unused on this build, centre spur will be used though,
diffs seem very well built tbh, even the plastic cases are glass reinforced,
but plastic will probably go away for alloy alternatives when its final built,
reason to clean em is there gonna be in out in out etc and no grease means less messy ,
