steel carrier?
newton540
ohio
hello,
i just bought the cat 5 upgrade spur and pinion gears and I wanted to get the steel carrier that raest behind. where woudl i go to find this and which one will fit the smartech big foot i have? any help woudl be greatly appreciated!
thank you.
these are the upgrades I have done, jetpro pipe, steel gears, aluminum front knuckles, any other suggestions.
Also what is the FG diff part 3 that will fit on the bigfoot// 8485 something..
Thank you!
newton540
ohio
thank you, I already have the pinion and spur, what is the plate that goes on behind there that holds up the shaft for the pinion and spur? i a m not sure which one to get or where to get it.
Thank you!
csp1971
Missouri
Check out duratrax.com for the instruction book to the Firehammer MT and/or check out TowerHobbies.com to order the parts.
