Stock servos buzzing
Lee101170
Hi all new here from uk,purchased a losi 5t 2.0 about 2 days ago connected everything up as per manual but the servos are making a buzzing sound? Rang where I bought it from guy says it’s normal as they are hi torque servos? Does this sound right to you guys also the brakes are very very weak?
Hey thanks bud go on then how do I set the brakes please been out of this for a good few years now lol
see post above ??
blue bits top right pic below
they should adjust ur brakes aslong as its with in adjustability.....that make sense ?if not trims set to 0 and servo horn off....and then bak on set up?
I took servo horn on but can’t get it to go bk on straight if you know what I mean it at an angle either way? It wasn’t straight from the off.
ok...turn ur tx on....set throttle trim to 0 then put horn bak on....u may have to undo/unadjus the 2x blue adjusters a bit to get horn bak on
better still get ur manual an it will tell u brake set up step by step ?
